G
For years my overdrive unit will only stay engaged for about 5 miles then kick-out. It is as if the oil gets warm and it quits working. I thought for sure I had figured it out after reading an article about not using detergent oil in the transmission/O.D.. I changed the 10/40 Valvoline to a straight 30W non-detergent but it had no effect. Could lever setting or a weak solenoid do this and be so consistent?
