BT7 Grille surround
JPSmit
Bill you are asking in the wrong place - perhaps a forum moderator can help move the question, or, repost in the austin healey section - this is really for technical help with the actual forum. good luck!
Administrator
Boss
Bill, as JP said, you asked your question in the wrong place. You posted in the "forum help" forum, which is meant as a place to ask questions about how to do things on the forum (like how do I post pictures, or how do I add a signature to my posts, etc).
I'm going to move your topic to the Austin Healey forum where many AH owners will see it and you will be more likely to get replies to your specific question. If you are reading this you will find that you are now in the Austin Healey forum.
Regards and welcome to the BCF!
Editor_Reid
Platinum
Yes that is so but I have been told that the BT7 MII used mat Black not grey.
According to the Concours Guidelines (All rise!):
3000 MK II and MK III cars have grille teeth of anodized aluminum. Grilles with chrome-plated teeth will be scored as incorrect. The chromed steel inner oval grille surround piece overlaps the upper chromed steel hood piece. These models should have a light flat grey dull silver band of paint around the inner 3/4" to 1" of the inner grille surround (to the ridge peak), which was to prevent reflection of the teeth in that surface and hide the spot welds used to attach the lower mounting brackets.
B
BillRichards
Thanks for your help.
Healey Nut BT7 Windscreen Pillars Austin Healey 4
F My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
D Very Nice 80% restored BT7 Austin Healey Classifieds 4
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 1
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
F After 30 years of ownership I decided to clean my 1961 Healey 3000 BT7 Austin Healey 0
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut BJ8 and BT7 parts for sale Austin Healey Classifieds 23
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
F Help need reinstating my heater - BT7 Austin Healey 7
AH67 Air Cleaners for Mark I BT7 Austin Healey 4
F Water pump replacement on my BT7 advice needed please Austin Healey 18
N Help to identify parts - BT7 Austin Healey 7
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 14
N Searching previous owners - BT7 Tricarb -62 sold in LA Austin Healey 5
Drone Dog BT7 tach question Austin Healey 8
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
AH67 Polishing Foggy side curtains on BT7 Austin Healey 13
Drone Dog 62 BT7 squeak Austin Healey 2
Drone Dog BT7 top/paint protection Austin Healey 5
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
Drone Dog BT7 Oil Leak at Distributor Austin Healey 5
Drone Dog BT7 Timing Advance Austin Healey 17
R BT7 turn signals Austin Healey 5
Drone Dog BT7 oil pressure relief valve Austin Healey 19
Drone Dog BT7 rear wheel leaking Austin Healey 25
Drone Dog BT7 air ducting / cooling Austin Healey 20
