Hi all,
I've owned my 1961 BT7 for 25 years. Currently the brakes do not appear to works as well as they have in the past. The peddle has some travel and then has a firmish response. Pumping the brakes does not produce a higher or firmer peddle. When applied the brakes don't exactly bring the car to a shuddering halt, but are slow and progressive. In the past I am sure that the brakes had more stopping power.
The Master Cylinder is newish and the reservoir is only a year old. I have replaced the pads and shoes this week. I have bled and adjusted the rear brakes, but not bled the from calipers.
My thoughts are:-
1) Is there still air in the system? Could air be trapped at the highest point in the system where the pipe enters the MC? I have tried pumping the peddle and loosening the brake pipe nut but only fluid comes out.
2) Could there be a problem with the MC? How can I test the system to try and isolate where the problem might be?
3) Have the brakes always been inefficient and I am somehow remembering them being better than they were?
Any advice welcome.
Phil
My thoughts are:-
Any advice welcome.
Phil
Hi Guest!
