Deleted member 21878
well i was rolling right along today until...
i went to gap the rings.
ring gaps for all compression rings (checked at least one from top, 2nd and 3rd groove) in all cylinders was pretty consistent. problem is they all were between .022 and .024.
the manual calls for .013-.018. my cylinders have been honed but not bored. i had the maachine shop check the bore while they had the block. they said they were all standard. i just went back out and checked them with my bore gauge and it showed 3.28, which means i am off a little i guess.
either way it looks like the cylinders are standard. these are hastings rings from Moss. part numbers on the box look correct as do the stickers put on by Hastings.
any of you all run thru this before? anything else i can check?
Make sure none of the ring gaps line up with each other and build it .
