Did you use por15 on the entire differential? The pics look like you did - and have you tried the Hirsh miracle paint? I have more of that than the POR and I need to do the undercarrage now that the differential is out.
Hi Darrell; It goes on very similar to the POR15 stuff maybe a bit thinner - Just finished coating the differential and underside with it 2 coats - gotta remember to wear gloves - the stuff does not like to come off even with acetone! A badge of some sort eh!
Hi Paul - it is very similar to POR It hardens like it - cannot resuse the container once opened - like POR - so chemically - a polyurethane that cures with moisture - just seems a bit thinner to me - but I am brushing it on so - if I sprayed it on - I may notice other aspects.
Getting ready to RR the pinion seal - looks straight forward from the Bentley manual - any comments to help?
