Who needs directions?Sept. 18, 19, and 20 in Fayetteville Arkansas, only British cars in the show.
WHO'S GOING? Directions on line. PJ
A bit too far for me.Sept. 18, 19, and 20 in Fayetteville Arkansas, only British cars in the show.
You could also add this to our Events forum, that way it will show up on the events calendarSept. 18, 19, and 20 in Fayetteville Arkansas, only British cars in the show.
You just post in the correct events forum (suggest the Local Events).How do you do that? I've tried a couple times in groups/public events, and it doesn't record any typing; it just jumps back to a daily list.
Hmm, I’ll take a look when I get back from church. Maybe there’s a problem I’m not aware of.Well, I have the calendar, but I've tried to get it to let me type in the daily boxes, and no go. brought up Sept. 18, 19, and 20, but I'm not able to type in the boxes. I must be loosing it!
Just make a post like a normal post with teh details and any links to associated web sites, then save it. Just like any other post. Then, once you save it, click the three dots in the upper right pf the post you just saved and select "Calendar Menu" from the dropdown. Then click the "Calendar Add" button. From there, just select the start and stop dates FROM THE dropdown calendar. Don't type into the fields, just select from the popup calendar. I've got ahead and added it and linked to their website.Well, I have the calendar, but I've tried to get it to let me type in the daily boxes, and no go. brought up Sept. 18, 19, and 20, but I'm not able to type in the boxes. I must be loosing it!
You should retire so you can get some rest and relaxation.OK. Thanks, Basil. Later as I have a job to do at the present.![]()
