Born_Loser
Got a new problem. Back story - had a leaking master cylinder. Ordered a rebuild kit from Moss (Gerling system - so I did both clutch and break master cylinder). While I was at it, I replaced the fluid reservoir . Since I had it apart, I rebuilt the peddle assembly - it was a mess, with the shaft seized to the break peddle - and the end bolts removed. The peddles are both free, and have a fraction of the lateral play they had before. I bled both systems, and noticed a bit of small black pieces in the clear bleed tube on one of the rear breaks. So, I ordered stainless steel break hoses, and replaced all 3. Flushed all the fluid, and the bleeds where clear. Clutch works like a champ. The breaks have very little travel, and when I stop for more than a minute after a short drive, all 4 breaks are locked. If I stop at a stop sign, they drag for a second and then free. But, if I park, they will be stuck in a minute or 2. I honed both masters, and the seals looked identical. Suggestions on how to diagnose the cause?
