healeyboz
So I only got about 200 miles on the new motor and need to tighten up head bolts and such. I was hoping to get the 500 on her and see a bit of oil forming around the head gasket. I also noticed a bit of carbon coming from the exhaust port. I guess I need to tighten the two header bolts in that area.
QUestions:
Sequence for head retorque?
I can't remember the lbs for the ARP bolts. They do have the ARP lube on them.
Valve lash ??? What would be the best setting? -- cold or hot?
Any other suggestions would be appreciated???
Anything to check besides regreasing fittings? And making sure all is still tight?
QUestions:
