steveg
All the Healey cylinders are aluminum with a hard finish on the inside. This is destroyed by honing. Therefore if there are any problems, replace.
In addition to BP NW (which, if they have a part, generally have the best price on it), Pegasus Auto Racing carries original Girling replacement cylinders, clevis rods & clevises at very reasonable prices. The cylinders are by bore size and are marked on the outside of the casting. When I went thru this last year, one or two of the Pegasus cylinders were quite a bit cheaper than those at Moss.
FWIW--my understanding of the rubber problems is they only affect 20-year-old NOS replacement parts and the modern rubber works with anything. I've been using NAPA DOT-4 fluid for a couple of years and have had occasion to examine the rubber after a few months of use and observed no deterioration.
There has been a problem with clutches and brakes staying 'on' after application, and it my case it was with a Moss replacement cylinder where the rubber ring seal just inside the circlip was positioning the piston just far enough forward to cover the feed opening from the reservoir, thereby preventing the pushing of the fluid back up toward the reservoir during retraction. On removal of this seal, the cylinder works properly.
