jjbunn
I never realised, when I got Harold, how much time I was going to spend fixing the brakes! First it was the master cylinder, then the rear brake lines and hose, and now I am on to the rear brake cylinders. The one I have taken off was gunged up solid. So today I have been cleaning it out, and will fit the rebuild kit I got from Moss at the weekend.
As for the speedo: I have a new (used) angle drive, a new (used) trunnion, new gasket, and I already installed a brand new cable. So far so good. Today I drained the gearbox oil. Boy, there was a lot of it! It looks, from the manual, that refilling it is going to be a pain, as it requires a squeeze bottle. I need to refill it after attaching the new speedo parts.
Question: if the gearbox oil is drained, and I feel like tinkering with the carbs, can I do any damage starting the engine with no oil in the gearbox? Or should I wait until the gearbox is refilled?
Hi Guest!
