Morris
I helped a friend of mine rebuild the brakes on his MGB recently. All of the top end hydraulics are the same as the late model Spridgets. Now the brake warning switch assembly is leaking like a sieve. I dismantled it and checked the seals and bore before bleeding the brakes, and everything looked fine, but still it leaks like crazy through the switch hole.
Any suggestions on how to address this problem?
