On my Nissan van - Lucas brakes. When I hit the brakes hard, the brake warning light flickers on. Usually this is supposed to be a warning that the reservoir is low, but I filled it up to the high line and it still flickers on. Do the floats in there loose their floatiness? or should I be looking for some other problem. I went over the pipes / brakes etc, no signs of leakage, pads and shoes good... just the idiot light has started to flicker on when if I push the brake pedal firmly.
Hi Guest!
