TR6 BRAKE TUBING KITS
PDIGIO_6x3
Hi All,
I am going to replace all the brake tubes on my '72. Looking on the Rimmer Bros site I see Imperial thread, or metric. Has anyone run into a metric set of brake lines on their car? I didn't know they actually made anything but the Imperial thread. If there's a date range, let me know. Thanks. Patrick
Sarastro
I have never seen brake hydraulic parts, for these cars, with metric threads, but I have seen fittings with Imperial threads but metric-sized flats. Perhaps that is what they meant.
In any case, I saw the line sets in the sale brochure from Rimmer, and I was surprised by the cost. The line sets were close to $200. For comparison, a similar set for my Porsche, a few years ago, was under $60. And that is for an early Porsche, where we all are inured to getting reamed on parts prices.
You can get a beautiful flaring tool from Eastwood for $200: > Eastwood Professional Brake Line and Tubing Flaring Tool < .
Then a roll of tubing and some fittings, which shouldn't be more than $50 from Federal Hill (http://www.fedhillusa.com/). For little more than the Rimmer set, you have the tool for future use.
PDIGIO_6x3
PDIGIO_6x3
After a little digging I see that the caliper is the determining factor only. They can have a metric thread in many of the later ones or aftermarket ones.
If you think Rimmer is nuts, look at Moss! $337 for the same kit!!
sp53
What I am doing on a tr3 is I purchased a 25ft roll of 3/16 brake line for 28.00$ from a local brake shop and the fittings from Rimmer for like 40.00$ because I need some early stuff that only Rimmer had.
Usually the fittings on British cars is 3/8- 24,UNF, however some of the fittings on the early Triumph stuff is 3/8 20,BSF.
Anyways I would wager a tr6 is 3/8 -24 threads per inch and UHF. I have found you can purchase the 3/8 24UHF at most stores.
I too have found the flaring is difficult to do sometimes/most times. The place I bought the 3/16 tubing will also flare the ends after the line is cut and bent providing you leave an inch of line free to work.
Steve
mctriumph
It is not so much the threads, as the flares on the ends of the tubes. You will have to
access a tubing flaring kit that can duplicate the flares needed.Quite a lot of FUN!!
It takes some level of craftsmanship to get it right.But the tubing is cheap and OTC.
Mad dog
malbaby
DIY is the cheapest and most satisfying option. The brake calipers are the only possible metric threads.
Do not buy a cheap flaring tool as they are a waste of money...There should be a shop close to you that can flare the ends.
Lynn Kirkpatrick Brake Pipe [tubing] Replacement MG 9
GregW Brake tubing, Reservoir to MC Austin Healey 4
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
