I've got the rear brakes off thanks to a leaky cylinder and I think it might be wise to replace the steel tubing while I'm at it. I'd planned to do just the two pipes on the differential housing from bulk tubing (the good stuff) and re-use the fittings, but I see that Moss and others supply the whole kit. It is also probably a good idea to do the whole car at some point and at 120 bucks, the Moss tubes, cut to size with the proper flares and fittings installed seem the best route. Thoughts?
Tom
Tom
