Brake servo installation
Tronch
I want to install a brake servo on my BT7.
I have all the spares but I d´ont find any picture or diagram on how to rerouting the brake pipes.
Is a LHD with the brake fluid bottle on the left front.
Any help?
Thanks
May also require increasing the size of the balance tube as non servo cars had 3/4 " and with servo increased to 1".
This was early 61. Bob
Hi Bob,
Balance tube? Do you mean the master cylinder?
N
Me TOO! I have never heard of a balance,"tube", pipe unless it involved V8 engines and dual exhausts.-----Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Hi Tronch,
I don’t have any photos of how the pipe routes from the master cylinder to the 3 way connector. It basically goes from the MC down the scuttle brace to the frame near the front lower A-arm mount. From there, it runs along the backside of the front frame cross member next to the fuel line. Then it goes up the other scuttle brace to the 3 way connector mounted on the inner fender. Hopefully someone will have some pictures of what I just described. The first photo I DO have is of the 3 way connector, which links from the MC to the servo and also has the brake switch mounted to it. The second photo shows the 4 way connector which is mounted closer to the front of the car. Hopefully there is a welded nut on the scuttle brace for you to attach to.
Well Keoke, I got one of them balance pipes on my exhaust, and it ain't no V8! /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
/bcforum/images/%%GRAEMLIN_URL%%/nonono.gif Nasty things. Shoulda siamesed em, or you can take it out now since you not using the V8---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Since Tronch's car is a BT7 without servo it is possible that it is a tri carb model that has a balance tube or pipe that connects the 3 intake manifolds together. On non servo cars this pipe was 3/4 " in diameter and on cars equipted with a servo the pipe sized was increased to 1". I am not familiar with the 2 carb setup. For a picture of this tube look at the manifold set up in the moss catalog. Bob
Hi Bob,
Ah HA! I see what you’re talking ‘bout now. I was thinking you were referring to the bore sizes of the servo vs. non-servo master cylinders. On my old duel carb manifold (BJ8), there is no balance pipe. Both SUs fed into a common log.
There for a while I thought he was talking about Proportioning valves Greg. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif However, Bob I do not know why the balance pipe size was required to change unless it was thought necessary not having the one way valve in the early kits.--Keoke-?
S Brake Servo Installation Austin Healey 13
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
S Brake Bleed after Servo Installation Austin Healey 4
M Brake Servo Austin Healey 8
M Brake Servo Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
Walter74 Brake Servo Location Austin Healey 6
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R Brake Servo Rebuilder Austin Healey 14
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
H BJ8 Exhaust System and Brake Servo Austin Healey 16
C TR6 Brake servo leaking Triumph 3
B Power Brake Servo for a 100 Austin Healey 3
M Orientation of Lockheed brake servo Austin Healey 2
R Healey Marque Brake Servo story Austin Healey 6
N Spitfire brake servo in a spitfire Triumph 3
D TR6 Brake servo and rear tire rubbing Triumph 4
R BJ8 with servo...Brake travel issue Austin Healey 30
R Installing an aftermarket brake servo kit Austin Healey 6
S brake servo Austin Healey 3
L BJ8 Brake servo Austin Healey 6
D TR6 76 TR6 Brake Servo Triumph 2
W brake servo install? Triumph 1
W brake servo Triumph 3
W Brake fluid in Servo/booster Triumph 5
D Brake servo Austin Healey 1
Frank C. Brake Servo Replacement Austin Healey 6
T 77 with twon SU's- need to remove brake servo MG 2
John_Mc Brake/Servo issues Triumph 7
T XKE Series 2 Brake Servo Jaguar 2
B Brake Servo Parts... Triumph 1
B brake servo plumbing for BJ7 Austin Healey 8
J hints on rebuilding brake servo? Triumph 9
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
D brake servo Austin Healey 6
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
J Is my brake servo working? Austin Healey 5
chicken Brake servo pipe routing Austin Healey 1
RomanH Brake Servo Triumph 2
N Brake servo air filter Austin Healey 2
John_Mc Brake question. Servo? Triumph 7
A brake servo booster help Triumph 3
J Brake servo Austin Healey 4
C BJ8 brake servo options Austin Healey 5
A brake servo change out Triumph 1
N Brake Servo Lockheed Austin Healey 0
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J Repair of brake servo's Austin Healey 19
J Brake Servo mounting measurements Austin Healey 3
