Brake rotor questions
Re: Brake rotor & brake questions
Came across an article here on the net about cross drilled disks, was interesting, wish I'd saved it :frown:
I did a search and could not find anything.
I got the rotors today and started prepping all the parts. I have Powder coated cross member and all the other parts have been blasted, etched primed and black polyurethane coated. A steering rack has also been prepped and filled. King pins are rebuilt and calipers check out ok. A few more bits and I'm set.
Gotta get some pads, and bump stops and I think I am ready.
As long as they have not been overextended from worn out pads and they function smoothly and you are able to depress them easily? If so, they should be fine. :thumbsup:
Good. I put them in the vice and to depress the pistons. The pads that were in them were still fairly thick so they were not out very far.
