drambuie
Doug.... The best advise i can give you... Get yourself a offical Bentley Manual! It is a manual every British car owner/restorer should have. No matter what Model you own! I bought mine on ebay. The goal is to add or subtract the shims until you eliminate end float while still allowing the hub to turn freely, Start out with "excessive" end float and start subtracting shims. The stub axel nut should be torqued down between 40 to 70LB/FT. while still achiving minimum end float. Mine ended up at 65 LB/FT with about .002 end float while turning freely. Chances are you will need to buy a shim kit at Moss. You will also need a thousands dial indicator with a mag base,micrometer to measure the shims, and torque wrench. Michael, IL.
