All,
I'm resurecting a 78 Spitfire that spent 11 years in a barn. I'm almost ready to get it on the road except that I have a brake problem. The brake pedal is soft and goes to the floor until it's been pumped a couple of times. Once it's not going to the floor any more holding pressure on the pedal causes it to slowly move toward the floor, as if it's not holding pressure. Also, once it's been pumped up and is momentarily holding, if I back off the pedal just a little and then press again it goes easily to the floor. As if there is a valve that's causing the pressure to be released when the pedal is backed off slightly.
I'm thinking that the inside of the master cylinder is too pitted and so fluid seeps arount the plunger seals. I recently honed the master cylindar and replaced the rubber parts. I rebuilt the front calipers and replaced the rear wheel cylinders. There are no visible fluid leaks.
What do you think is the problem?
