Brake parts
jsfbond
And sometimes I do.....Break parts.
Is this brake valve available? or just the switch?
According to the Canley website, your switch should be the same as the TR6 switch
(Stanpart 149971). Roadster Factory has it listed on sale (so probably in stock) but it's a bit expensive ($60 even on sale).
Legend has it that a Ford C8AZ-2B264-A will fit and work, but I've not tried it myself.
https://store.spacecoastshelby.com/1968-f...switch1968.html
tdskip said:
Which part did you break?
The one without any number associated with it. the housing is...not looking good.
Again, just the switch w/o the body. But the Ford switch is the same (I have one).
How is it that the the ford unit is advertised @ $18.99, and the triumph one through VB is $59.95??????? I just called the local Ford garage and was quoted $26.91... if its the same,same.
The Ford part is # 1 above. Is that what you broke?
You said you broke the housing, the 4 port deal.
Is this correct and how can you break it?
Not quite same-same; the Ford part looks different (at least in the photo I saw). So in one case you are paying for a limited run reproduction of an obsolete part; while the other is a high production functional equivalent.
Now look up what the Ford PDWA costs, compared to what Rimmers gets for the Triumph part ...
because the owner of VB wants to be a billionaire! :devilgrin:
not sure of the methode used to remove the remnants of that part, from the threads from the housing years ago.
