I am rebuilding my brake mc and can not figure out the easiest way to remove the secondary plunger that engages the reservoir? It is the hexagonal piece in the picture...
I inserted a machine screw backwards in the tipping valve area holding it in a vice-grip and tried to remove but it doesn't budge!? I read to apply pressure on the plunger while you unscrew the nut, but Im getting nowhere!?
I believe you are on the right track, that nut (the hexagonal piece) is just really tight. Nelson wrote that he was able to use a pipe wrench on the shank of a 5/16" bolt, but I would suggest getting a proper 1/2" Allen wrench. An overnight soak in PB Blaster would probably help, too.
