Jarhead
I am trying to rebuild the master cylinder on my '77 MGB. I have the master cylinder off of the car. I have dis-assembled everything except the Pressure Differential Piston Assembly. Applying air pressure to the primary outlet as the manual directs, nothing happens. Very little air passes thru the PDRA chamber and the assembly does not move. Any advice is greatly welcome.
