bighealeysource
Quick question/s - just finished replacing the brake wheel cylinders on my 56 100M and did an initial bleed using a pressure bleeder. Did not get good
results even though I got a good seal on the power bleeder plastic cap to the brake reservoir. No apparent leaks from brake master cylinder and it was
replaced about 15 years ago. I will admit I did not check it when system under 15 pounds of pressure so if I do not see any fluid leaks should I
assume it is okay ?
Also, any recommendations on using the power bleeder ( Motive brand) on a 100 ? I have read about everything out there from past postings but
could not find one specifically about using a Motive pressure bleeder.
Thanks,
Mike
assume it is okay ?
Thanks,
Mike
