Trevor Triumph
My wife was driving back form the dump the other day and noticed the brake pedal was going almost to the floor-no brake fluid! Today I went to look things over, bleed the brakes and move the truck so I can the Spitfires out of the garage. When I asked her to push the brake pedal I noticed a stream of fluid running to the ground. There was a hole rusted through the line. While trying to undo the union, I broke the other part of the line at a union. I have a bending tool, a borrowed flaring tool- I'll just get some line at the NAPA store. That was at lunch time. After supper and the truck is still on stands and I can't get at the other end of the rest of the brake line. It sits on top of frame crossmember. If I could get the box of the the frame or remove the gas tanks it might be easier to get the brake lines. There is winding on the brake line, I imagine to protect the line. What that winding has done is provided a place for mud and crud to make a home. I put Kroil on the nuts and bolts and unions, maybe tomorrow I can get the thinks off. Then I'll try to re-route the brake lines
