Brake Line Lengths
mylesw
Hello
Does anyone know the length of the brake lines that run across the rear axle on a BT7? I need to get some made up and don't have any to copy.
Thanks
Myles
Hello
Thanks
Myles
I'm using for my rear disc setup: 16" (41cm) and 43" (109cm) - you could add 4cm to each of those and be extra-safe.
You could verify the exact lengths needed by running lengths of house wire between the axle tee and the wheel cylinders, bent to shape, then measuring those.
