brake line flares
kalist
I have restored many cars but this is my first Sprite. Can someone tell me how to form the ends on the brake lines. It appears that you start a double flare but don't complete it as you would on an American car. Any input would be greatly appreciated.
Is called a bubble flare.
Yes Jack is correct, and there are actually two different forms of bubble flare. Luckily, the interchange safely.
Thanks for the replies. I have a good flaring tool. My question is how to form the bubble flare. Am I correct in my assumption that you do not complete the double flare as you do on American vehicles?
you are correct, one of our experts will be along shortly to remind us all how to do it.
I have a set of copper BE brake lines left over. Not sure it's complete but I'm probably going to sell it. Flare ends done, fittings installed, I think there's four pieces in the kit.
If you look at the drawings for each type of flare, then there are two types of bubble flare - the modern DIN/ISO flare and the older Girling flare. Fortunately, as Trevor has said, they are pertty much interchangeable, particularly if you use a tubing line Cunifer, which seems slightly more maslleable than normal steel tubing.
And yes, you can get away with quitting a double flare half-way through.
"Pace" professional automotive engineers. I'm just saying what works!
Ditto what the other guys said.
By the way, welcome! We have a summer place in Andover, NJ.
