Hi Guest!
John Turney said:It will be on the inside of the right frame rail under the distributor.
TOC said:One way to check it by yourself is to A) find it, B) unplug both wires, C) jumper the two together (paper clip should work...just don't let it touch anything), D) ignition on, E) get out and look at the brake lights.
If they are on, the switch is bad, replace it.
If they are not, come back for more troubleshooting.
Dave
Donny_L said:okay, one of the fuses is cooked but I think it's been for a while. The other one was just a bit loose. When I tightened it the breaklights came on while the wires were together and the horn works again. So my switch IS bad,right.
Two questions;
1] can I get one of these switches at the local part store?
I doubt it these are British fuses "Lucas" . However, you can replace the 50 Amp one with an American fuse of the same physical size rated at a capacity of 35 Amp. OK.
and 2] are both of these fuses supposed to be 50 amp?
No originally one was a 35 Amp and the other was the 50 Amp
Donny_L said:There's only 2 fuses. So witch one goes where? 30 on top and 25 on bottom? or the other way around?
[/quote
Yep it's the other way around---- :laugh:
Donny_L said:Well I went to the parts store and the guy sold me a switch he said should work.When I took the old one out it leaked some brake fluid out. Since the switch is hydrolic it shouldn't work until I bleed the lines and get the pressure back up.
Well usually it is not necessary to bleed the brakes but at times it can be required.
Am I on the right track or did I just buy a $21 piece of worthless junk.
I am not sure just have to wait and see,never used anything but a known correct replacement part.--Keoke
Donny_L said:Well now I got real trouble. When I went to top off the break fluid I noticed some nasty stuff floating in the resivour. It looked like snot or flegm. So i took off the res. and cleaned it real good,refilled the res with new clean dot3.
Dut 4 would have been better.--- : :frown:
Then I went back to bleeding the breaks. Some of that nasty stuff must have gotten into the lines and now my front left brake is locked up.NOW WHAT ????
1] disconnect that brake line at both ends and blow it out with air and Pray.
2] You may have to do the same to the caliper with the pistons out----![]()
