Lin,
Edit your post and do a double click on the picture and select the size you would like,
Wana,
I appreciate the issue is getting confusing and your simplest approach would be to just change the switch. However, finding the real cause of the problem is something I would continue to pursue until identified. To answer your question about residual brake hydraulic pressure without having the brakes solidly on, residual brake line pressure not sufficient to lock your brakes could remain in the system should something block its return through the MC. Although not sufficient to apply the brakes, it could be sufficient to trigger the brake switch at the low point of its required pressure range.
You mentioned resetting the switch/circuit by disconnected and then reconnected the electrical connections and, I assumed, pumped the brake peddle to validate it was now working properly. However, you stated the brake lights are now working but required less peddle pressure/travel (then prior) to activate the brake lights. This gives me pause as either the switch function has been altered and now requires less pressure to activate or there is a level of residual fluid pressure in the system and now requires a smaller amount of additional pressure to trigger your switch.
To test the switch, I would disconnect the Green/Purple line and either attach a multimeter or light bulb to that switch contact to check how the switch reacts when the peddle is pushed. Observing proper operation would lower the probability that the switch is defective. If you experience switch hesitation or delay, I would consider the switch as trash. Next, raise the car and spin a front wheel. If you note any resistance or brake drag, it is probable you have some residual pressure in the brake line. Since these are only preliminary tests, they would give you some follow-on direction.
Since this cold be no more than a transient occurrence, I would enjoy my Healey until a second instance of the problem is experienced.
Good luck and be careful,
Ray(64BJ8P1)
