T-Series Brake Issue
hawksguy15
Hi All - So my father recently acquired a 1952 MG TD. It has been partially restored and we will be working to finish it up. When we got the car, the front brakes had seized. We were able to free them and get them adjusted and thats where we ran into a weird situation. We went to bleed the brakes, I was on the pedal and he was at the brakes. Once we had all of them bled, the brake pedal will not not budge. You have to put your full body weight on it in order to get it to move but it also will not engage the brakes. They will continue to move. Anyone experienced this or have any recommendations on what to do next. First time working/restoring a European Car.
JPSmit
First of all welcome and congratulations. Sounds like a great project. How long since it was worked on? Almost always the first thing to check is the brake hoses - two at the front and likely one at the rear. They perish internally and act as one way check valves - they won't let the fluid back. I would change the hoses regardless.
Mickey Richaud
:iagree: - J-P is on to something regarding the hoses. I'd be concerned about the condition of the fluid as well, especially if it's an unknown at this point.
And welcome to BCF!
I'd do all that and replace the seals in the master and wheel cylinders, maybe even just replace the wheel cylinders. If it's been sitting for some time then even if they aren't leaking right now they probably will start with actual use since the rubber doesn't like to sit and the fluid may have collected water.
Grantura_MKI
Would remove and replace all the components and start fresh. Send the cylinders out to be sleeved, and replace all hard lines. Be sure that the liners are fitted right way round. Check pedal shaft for wear and re sleeve, lube as necessary.
Brakes are not to be over looked, as they along with steering are the two most important components on a vehicle.
K TR2/3/3A Brake issue? Triumph 8
EricJNewman MGB Weird Brake issue finally solved. MG 1
Michael Oritt Brake issue Austin Healey 24
Rob Glasgow Brake Issue Austin Healey 42
J Spitfire Electric brake switch issue Triumph 5
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
V Weird Brake Issue Austin Healey 18
MikeAH100M Brake Issue on BN2 Austin Healey 4
O jag 420 brake issue Jaguar 3
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
B TR6 Brake Issue Triumph 4
R BJ8 with servo...Brake travel issue Austin Healey 30
Z TR6 TR6 Brake Issue Triumph 8
Stinger TR4/4A TR4A Brake Fluid Issue Triumph 5
CCURTISS TR2/3/3A TR3 Right Brake Light Issue Triumph 5
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
