Brake Issue on BN2
MikeAH100M
Went for the first ride of the spring yesterday. The 100 ran great until we couldn't avoid one of Pennsylvania's ubiquitous potholes. Front right took a shot and we immediately heard an intermittent metallic noise from the front right. Sounded like bearings to me (had plans to rebuild both front hubs this week) so headed for home, luckily only about 3 miles away. About 1 mile from home, the brake pedal became rock hard but I could still stop the car. When we get into the garage, all 4 brake drums were very hot and the wheels almost locked. After cooling off, the brake pedal softened and the car rolled easily. I am assuming that heat from whatever occurred in the front right caused this issue but any other thoughts on what to look for? Have not pulled any wheels yet.
Michael Oritt
Mike--
If all wheels were affected then the problem or cause would have to be in something common to them all unless somehow pressure from the front right somehow transferred back from the right front wheel cylinder to the other three--an unlikely scenario.
Is it possible that when you hit the pothole you also hit the brake pedal hard with your foot and somehow caused the pedal to remain partially or fully engaged? That seems unlikely as you would have been aware of having done so. However it is possible that you stepped hard on the brakes when you hit the pothole and somehow deformed the master cylinder rod and/or plunger and the pressure then transmitted to all four wheels, though why this would have "healed" after your return to the garage I cannot understand.
In any case I would look carefully at the brake circuit, starting with the pedal action and then seeing if the MC is operating properly. As always, please report back and next time take that drive in Maryland where the roads are great!
Healey 100
Mike:
The brake actuation rod and brake pedal linkage must allow the master cylinder piston to move back all the way to expose a tiny bleed port that lets the brake fluid return from the wheel cylinders to the master cylinder reservoir. Without the bleed port, the brakes pump up a bit with each actuation until they finally won't release the shoes from the drum.
Make sure the external brake return spring is present and working. If so, adjust the screw so to shorten the rod just a tad. Chances are this will fix the problem. I did have one non-Healey where the bleed port managed to plug up from debris in the brake fluid. If that's the case, you may have to remove and clean the master cylinder very thoroughly to fix the problem.
If the port is open, you can pump the brake repeatedly and the pedal should not pump up.
Bill.
MikeAH100M
MikeAH100M
Thanks for the ideas. The master seems like a likely culprit. The car goes up on jacks this weekend and I'll let you know the results.
MikeAH100M
MikeAH100M
The Master Cylinder was the culprit. The return spring missing didn't help either. I could not get the master apart to see what was wrong inside but it did not "plunge" smoothly and got hung up. Decided to pull the hubs while I had the drums off to check the brake lining. Good thing I did, there are no bearing spacers on either front axle. Good time to replace the bearings . . . . there's always something.
Thanks for the guidance.
K TR2/3/3A Brake issue? Triumph 8
EricJNewman MGB Weird Brake issue finally solved. MG 1
H T-Series Brake Issue MG 5
Michael Oritt Brake issue Austin Healey 24
Rob Glasgow Brake Issue Austin Healey 42
J Spitfire Electric brake switch issue Triumph 5
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
V Weird Brake Issue Austin Healey 18
O jag 420 brake issue Jaguar 3
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
B TR6 Brake Issue Triumph 4
R BJ8 with servo...Brake travel issue Austin Healey 30
Z TR6 TR6 Brake Issue Triumph 8
Stinger TR4/4A TR4A Brake Fluid Issue Triumph 5
CCURTISS TR2/3/3A TR3 Right Brake Light Issue Triumph 5
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
