Brake Cylinders
mylesw
Hello
I have another simple question for all you experts out there. I'm trying to refit the rear brake cylinders to the rear backplate of my TR4. I've put on the first two spring plates however I seem unable to get on the third plate. There's insufficient space the get it in flat between the handbrake lever and the cylinder. So each time I try to push it in it just digs into the cylinder. Am I doing something wrong? Is there a special technique to doing this? Thanks for your help.
Myles
Myles-
Try the BCF WIKI - on the left menu. Go to TR6, great visual on how these go together.
Randy
Thanks for the link...no wonder I couldn't get it to work. Having removed the first two plates and I have now re-installed them in the correct order and all is well.
Thanks
Myles
