Brake cylinder crystals
Bill Young
Healey Friends
How about the chemical experts in our group. We have been changing out brake cylinders at our recent shop meets and find significant corrosion with a build up of some sort of green “growth”crystals. We ask where this comes from and if there is any prevention? Take a look at this picture. Thoughts?
Healey Nut
I’m no metallurgist or chemical expert but take a look at battery terminals that are not protected , combine that with leaking brake fluid and voila ....greasy green goo .
Madflyer
I would have said salted roads but where you live unless sea air or driving on the beach. Try a spray coat of clear lacquer. And on the side a grounding problem cause Electracies. Madflyer
Good question. Can you correlate with type of BF used; i.e. DoT3 or 4? I had the LMH DoT4 in our BN2 turn to a (greenish) gel after it sat for several years. I replaced it with Pentosin brand--recommended for BMWs and other German cars--and a couple cylinders leaked. Tom Monaco told me to only use Castrol DoT4, so I'll try that next.
DoT3 is mostly ethylene glycol, DoT4 also contains borate esters; boron is a semi-crystalline element that produces a green flame when heated by a torch. If this problem only occurs with DoT4 and not DoT3 I'd strongly suspect the borate esters. Of course, DoT3 was originally spec'd for cars of that era, but DoT4 has a higher boiling point. Note DoT3 is often spec'd for ABS systems, supposedly because it is less likely to aerate/foam as ABS systems can cycle rapidly.
For all the horror stories about DoT5 (silicone) BF, I've been running it in my BJ8 for at least 20 years and never had an issue I can attribute to the fluid. Of course, silicone is made from sand, and crystallization wouldn't be surprising, but I've never seen or heard of it happening.
BigGreen
GregW
Platinum
Silicone itself is made up of carbon, hydrogen, oxygen and silicon. Note that the ingredient contained within silicone is spelt differently. The ingredient silicon comes from silica which is derived from sand. ... It's then mixed with the other chemicals to create silicone.
That sounds a lot like Subway's description of their sandwich bread several years ago.
See; https://silicone.co.uk/news/where-does-silicone-rubber-come-from/
I know the difference. It was a bit of a stretch, but because silicone is a compound containing silicon, I speculated that it could crystallize--"crystallization wouldn't be surprising"--though I've not seen it happen. Silicone is great stuff, I use a 'dry silicone' lubricant where a light lubricant is required--e.g. speedometer cables and starter worm gears--as it doesn't seem to attract dirt and gunk-up as much as petroleum-based lubricants and, of course, it has certain, er, 'cosmetic' applications.
I mentioned that I had DoT 4 gel in my BN2, and I'm replacing a wheel cylinder that appears to be crusted with the same sort of substance shown in OP's photo, but dried out. It appears this may be a common problem, and I'd like to figure it out. If the owners all used DoT 4, then the borate esters--I also know the difference between boron* and borate--could be the culprit, since DoT 3 doesn't contain borate esters (presumably, DoT 3 was originally spec'd for our 50s-era cars, but there was a DoT 2). DoT 3 would be sufficient for our street-driven cars, though racers might prefer DoT 4, 5 or 5.1.
* Incidentally, there's a town--actually, a 'census-designated place'--called Boron in California, home to a large open-pit boron mine. You wouldn't want to live there.
Healey Nut
Im thinking with all that silicone it has to parts of Dolly Parton and Kim Kardashians anatomy .
Madflyer
I have been to Boron CA several times there is a great Mexican Food place. It is a little town not to far from California City it is not on the main interstate. A TR 6 friend told me about it so we pulled off. It is a desert town about 20 from no where. As for Boron it self it is a chemical that has a used to clean up Radiation. It was on hand when I worked at a NUK power plant in Sacramento CA.( I do not Glow in the dark ) Madflyer
John Turney
Since it's on the outside of the cylinder, what you are seeing is probably dirt, brake lining dust, bearing grease (front) or oil (rear) and a bit of brake fluid. Old DOT 3/4 fluid does seem to crystallize and attract dirt & dust. Green may be from copper which may be part of the cylinder alloy.
When I rebuilt my brake system 20 years ago, I went to DOT 5 and have never looked back. A couple of years ago, I replaced the "rubber" pieces when I had to replace the pads. My thought was that since the non-brake rubber parts were cracking, I should replace the brake "rubber" parts too. The inside of the cylinders were pristine. "Rubber" is in quotes because it's probably EPDM elastomer.
Switching to DOT 5 requires complete rebuild/replacement of the brake system because it's not compatible with DOT 3, 4, or 5.1.
B
Bill Young
Thank you all for your comments..
Cheers
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
M master cylinder brake/clutch Tr3 Triumph Classifieds 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
bighealeysource Question on 100M front brake cylinder Austin Healey 4
D BJ8 brake master cylinder question Austin Healey 6
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
M Brake fluid on tire - cylinder need replaced? Spridgets 19
KVH TR4/4A Two Questions: Driveshaft and Brake Cylinder Fasteners Triumph 7
warwick-steve Rear Brake cylinder connection Austin Healey 12
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
dklawson General Tech Brake Maser Cylinder Pushrod Boot Installation Tricks? Triumph 2
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
richberman failed rear brake cylinder... Austin Healey 1
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
D MGA 1960 MGA Rear Brake Cylinder MG 2
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
R HELP! Wheel brake cylinder clip MG 9
memphis Rear Brake Cylinder Austin Healey 17
5 Correct rear brake cylinder size Austin Healey 1
letemglow Brake line layout with dual master cylinder MG 6
Gliderman8 Brake Master Cylinder info Triumph 1
doughairfield Brake Master Cylinder leaking Triumph 11
J TR4/4A TR4 Master Brake Cylinder Rebuild Triumph 3
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
