Braided Oil Pressure Line
jhorton3
Anyone here running a braided oil pressure line from the block directly to the gauge? There's a small hole, chamfered and I suspect is some kind of check valve. Oil keeps pouring out of it. I took it off to do some dizzy work, and this started. Before I could get 40-60psi on the gauge, now nothing. It's poured probably a half a quart onto the ground and that's without the engine running, just turning over with the starter.
I hate to admit it but I have the common "after market" 1/8" nylon tube from NAPA (with 1/8" b-nuts) on mine and it has worked perfectly for about 5 years so far (broke the metal tube and replaced it "temporarily" 5 years ago).
Bill
No valve in there. The oil pressure ie oil. just compresses the air in the line to move the gauge.
Bill
The "metal" tube is just 1/8" copper (available @ Home Depot) installable with standard brass compression fittings, real easy to install!!!
LOL
You can see my solution here.
Jeff
Yeah Jeff- I guess that with an engine that needs that stabilizer that you wouldn't need a heater!! Looks lethal!
Bill
I kinda LIKE the "torque compensator" /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
...it could use a bit o' paint tho. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Yeah, I know it could use some paint, Doc. This is still in the mock up stage to get everything located and test fit. Then it all comes back out again for detailing prior to final assembly.
Jeff
Just pickin' on ya, Jeff. It's early an' I couldn't sleep anymore. Consider it boredom relief. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
It all looks pretty good in there. Rib case at first glance looked kinda Hewlandish: "What th'... Oh." /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
I learned pretty hard on getting oil pressure gauges to stop leaking. Liquid teflon is the trick here. Don't use tape! The cheapy nylon lines that come with the gauges or bought seperately work just fine.
