jhorton3
Anyone here running a braided oil pressure line from the block directly to the gauge? There's a small hole, chamfered and I suspect is some kind of check valve. Oil keeps pouring out of it. I took it off to do some dizzy work, and this started. Before I could get 40-60psi on the gauge, now nothing. It's poured probably a half a quart onto the ground and that's without the engine running, just turning over with the starter.
