Well I bought the 1972 Blue MGB. The doors do have a gap about 1/16" at the very top and it opens up to about an 1/8" gap when jacked.
I opened up the rust and it seems very localized. The rear wing skin and the outer sill but only in that area. The inner has a waxy film on it and no rust. I took out the interior panel and looked down that hole an it looks clean.
The trunk has surface rust and a couple small holes. The drivers floor pan has 2 small holes in it, the right has only surface rust.
The right dogleg may have some of the same disease as the left but not as advanced. I just can't find any other rust through areas. I looked at a 1971 the other night and it was rusty so I kind got it figured out where to look.
Here is a link to some photos.
https://i225.photobucket.com/albums/dd50/Norton47/MGB/MGBTrunk.jpg
https://i225.photobucket.com/albums/dd50/Norton47/MGB/MGBRust1Dogleg.jpg
https://s225.photobucket.com/albums/dd50/Norton47/MGB/
He could not get this car to run but it did run when he parked it. He put in plugs, changed the oil, new points, rotor and cap and fuel filter but it was dry. Do these have mechanical fuel pumps? Looks like it needs fuel.
What is the shift pattern, is it a normal H with reverse all the way to the right and back?
I bought this for $500.00, it also has a snug top hardtop.
I am going to buy the underwater 1974 also and use it's bonnet and wing to fix this one I think.
Off on another adventure.
