Kevin Farley
I have just recently installed a Bosch Type 0 580 254 910 fuel pump on or TR6 injection (to replace the origianl Lucas Pump which was causing problems on hot days) and also a pre line 13mm inlet/outlet fuel filter Type 14001 on our TR6. After fitting the new Bosch pump the problem I have now is that it overworks for some reason - that is it runs with a high pitched sound and seems not under fuel pressure. The TR is still getting fuel and is still driveable
If you stop the TR, turn the engine off and leave a minute and turn it on again the fuel pump works fine. If you go for a run, then about after about 3 miles the overworking high pitched sound begins again. Has anybody had a similar problem when fitting the Bosch pump and is there a remedy to fix. The bosch pump has been installed just above the chassis rail under the back left-hand mudguard.
regards Kevin Farley
