booo ya!!!!! i fixed that baby.
7
76midge
you guys remember me? jason? i had the 76 midget clutch problem. well to day i fixed it. finally. i am so happy. i am gonna take it to school tomorrow. /ubbthreads/images/graemlins/cheers.gif /ubbthreads/images/graemlins/patriot.gif
je suis ce que je suis, et ce je suis ce que je suis, quest-ce-que je suis? je suis de la bomb.
76midge
it sure is, i was like "oh yeah!!!" i am still thinking i am dreaming. it was awesome. my dad tried fixing it for like an hour, then i turned the started once, and bam, it was fixed. i thought i broke something cause i started to roll after the car stalled. but it was still in gear. i let the clutch pedal go and i stoped. so i pushed it in and presto, it was working. i burned some rubber when i peeled on outta that joint.
G
LOL, neat, glad you got it fixed and are so excited about it. Looks like you have been bitten by the Little British Car bug.
76midge
i rode it to school with no problems. some guages dont work, like the speed and gas.
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
Flash_Harry MGB Fixed a miss! MG 7
F How is the fron valance on BT7 fixed to the car? Austin Healey 1
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
F How is the leading edge of the rear quater trim panel fixed on a AH BT7? Austin Healey 16
Gray_Cat Lotus Elan Fixed Head Coupe FS Malibu CA Lotus 3
Got_All_4 TR2/3/3A Door handle can this bee fixed Triumph 1
Healey Nut Can this be fixed ?? Austin Healey 24
P Fixed gas smell Triumph 0
nevets sputtering issue fixed...it was the timing Austin Healey 4
hondo402000 TR6 TR6 More issues fixed Triumph 3
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
drooartz I fixed something! MG 17
M Weeping fuel pump fixed Triumph 0
richberman Adjustable shock mounts or fixed? Austin Healey 16
Pythias Speedo ...... pffft..... fixed. Spridgets 3
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
martx-5 TR2/3/3A Fixed the tach on my TR3...Sort of Triumph 10
sparkydave Now what? [fixed!] Spridgets 12
H HS6 Fixed needle centering tips Triumph 1
T 1989 xj6 FIXED! Jaguar 2
mountainman TR2/3/3A TR3 Hard Steering!!!!!Fixed!!!! Triumph 4
healeyboz Intermittent problem finally fixed Spridgets 6
ModifiedBJ7 A-H Fixed-Head Coupe Austin Healey 20
zimmy fixed the gearbox?! bearings and bullets? Spridgets 4
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
Baz Vacuum advance fixed! Spridgets 9
RickB FIXED - Distributor removal 'emergency' [not] MG 39
RickB Distributor pull - 25D - ideas please? - FIXED! Spridgets 2
T Fixed Battery Leak-I hope Triumph 13
X Sagging door fixed MG 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
C Alternator is Fixed! Triumph 2
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
SCguy Get oil pressure gauge fixed or just find another Triumph 12
ncbugeye Can these be fixed without a complete repaint? Spridgets 11
Banjo Fixed my dads "clunk" MG 3
J Fuel Gauge fixed almost. Triumph 5
M Acceleration Fixed MG 1
sparkydave Just when you think it's fixed.... Spridgets 7
Scott_Hower DOT5 brake fluid leak FINALLY fixed ! MG 11
SCguy Overdrive Fixed! Triumph 3
Sherlock Wedge spotted at a car show... TR8 fixed-head-coupe Triumph 4
J 1958 xk150 fixed head jaguar coupe Jaguar 3
Kim de B MGB MGB leaks - fixed MG 5
Joel Lester TR2/3/3A Baby moons on myTR3 Triumph 3
S Baby Blue gets a Shout Out from BaT Spridgets 4
