Bonnets
dickc
Hello all,
With cold weather approching I am back on task with my sprite project and I am looking for some advice. I have a MKIV that I picked up that I am bring back to life. I have a mazda 13b installed and am looking to a nice one piece bonnet to cover it. Any Ideas? I would like a nice flare to hold some 8in wide rims. I cannot get a good pic og the Japco bonnet. Are they any good? Who else is in the market?
Thanks,
Dick
You most likely will need to buy a stock bonnet and lay your own glass to get the shape/size you desire. Did you ask spridgetech about doing a custom set?
Maybe Hap from Acmespeedshop will have some suggestions.
I've never seen any like that other than ones that were hand built from generic flares.
I have stock looking one piece fiberglass square-body bonnet/fender unit laying around behind my shop. It needs a bit of work. It is set up for a front tilt and has spitfire latches on the sides. Some previous owner laid something on the top section for a long time so it has a depression in it. I think it would be an easy fix.
That is a pretty big piece and I don't have any way to crate it. Do you think that Greyhound would ship something that big without being crated? (I guess I might strap it to a pallet)
If you think it is possible then I guess I would sell it for 150 bucks.
you do not have to crate to ship greyhound. they will take it as is with a address tag on it .Has to be taken to a greyhound station. This is the cheapest way, will go across country for very few bucks . Size must be less than 30"x 47"x 80" and not more than 100 pounds.How much work do you think it will need to be usable
sounds like scary way to ship a big chunk of glassfibre.
It was on a car when I got it. I don't think it would take too much work. The hood area has a dent sorta thing in the glass where something heavy sat there for a while???maybe? Looks like a dent in sheet metal...only without the wrinkles. I might iron out if you just reversed the process in the hot sun for a while. I will have to go out back and look it over again. I might take a photo and post it here if you like.
There are several palces that make fiberglass fender, hood and deck lids and bugeye front ends for our cars. I used several different ones.
Here's an example of Japco bodywork
www.acmespeedshop.com/_images/100-0002_IMG.jpg
Here's a example of Spridgetech bodywork
www.acmespeedshop.com/_images/bustertestday.JPG
Huffaker also makes nice body work for the Spridgets.
All this stuff is race weight, meaning fairly thin, so I would recommend thickening them up for street use.
Nice looking glass.
