jjbunn
For some reason the spring-loaded plunger on the underside of Harold's hood isn't going far enough into its receptacle (the cup shaped thing that has a knife-like spring-loaded catch at the base, that is opened by the hood pull), no matter how far I push down on the hood.
It's as if the bolt thing inside the spring isn't long enough, but it's hard to see exactly what the problem is while the hood is down
Any ideas what this problem might be caused by? I can see how to adjust the left/right position of the cup, but I can't see how that would help matters.
Thanks!
Thanks!
