[ QUOTE ]
dave,thanks but your responses seam to be in conflict,do you mean to say earlier issues had fully thread bolts and sub.had collers[smoth section up to the bolt had]? the collered bolts are slightly thicker in diameter at the coller then the threaded section .IMO.this smoth section helps in straingth when sheer loads are present i.e rear shock mounts,the threaded bolt especially when loss will act like a seratted ginsu knife.
[/ QUOTE ]
Hi Anthony,
I said that the earlier models had fully threaded bolts (should have said capscrews) & I didn't know about the later models. From other responses, it looks like none of the models had smooth shank bolts. However, you are correct. The smooth shank bolts with larger diameter shanks would certainly be "some" improvement & I would use them even if not "original". As I said, they won't completely prevent damage if they get loose, but every little bit helps.
