Bolt head size
MY66AH
Anyone know the size of the front crank/ bottom pulley/ balancer bolt head on a '66 Sprite 1098cc. Thanks.
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
Kleykamp TR2/3/3A Head bolt torque??? Triumph 9
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
G TR4/4A tr4a head bolt Triumph 2
mgnewbie I can't believe I broke the head bolt! MG 8
K TR2/3/3A Head bolt torque TR3 Triumph 3
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
Brosky Bolt in rear of head Triumph 14
wkilleffer Seepage/bubbles around #8 head bolt MG 15
D TR4/4A TR4 coolant leak thru head bolt Triumph 7
AUSMHLY Screw or bolt head used for back seat? Austin Healey 20
Z Head bolt fun Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
W Wanted Bolt on luggage rack Triumph Classifieds 4
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
maxwedge5281 front hubs for bolt on wheels Austin Healey 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
D Oil Filter Bolt Seal Austin Healey 2
C Tough Bolt on front of Crankshaft Spridgets 16
Scotsman TR4/4A Spinners for bolt on minilite wheels Triumph 0
G TR4/4A ARP Bolt Torque Specs Triumph 10
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
Csarneson Connecting Rod Bolt Question Austin Healey 3
maxwedge5281 Wanted want to buy! one bolt on 3000 wheel! Austin Healey Classifieds 2
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
