Hi again Mike,
Personally, I'd *like* to do it all, start to finish, too. That's just the way I've always felt about everything on my cars.
*But" that's really not practical, since a wide variety of skills are involved in a restoration.
I'd say go ahead and do the body work up through the sanding of the final body filler skim coat. The reason is simple... make a mistake and you can just do an area over. So long as you aren't rushed for time, you can fool around with it until it's just the way you like it. Materials aren't terribly expensive and a little waste is not a big issue since you aren't paying for the labor!
A final paint job can be touched up a little. However, it's not very forgiving. Use the wrong thinner, or paint at the wrong temperature, forget to use a tack cloth, or fail to control overspray adequately, etc., and a complete "do over" might be a big, expensive proposition, possibly even re-stripping the car. That's why I would opt to have the final paint done by a pro.
It's very important to work closely with the person who will be doing the final painting to insure all the work you do is fully compatible with the materials they'll be using.
Coddington or Foose may send cars out for premium level work and ultra-fast turn-around at a high cost. Your cost should actually be a lot less than it might seem at first, since it will mean you can avoid buying a lot of specialized equipment that you'll rarely use. You still might want the compressor, but needn't buy the spray gun, painter's suits, respirator, sophisticated air/oil seperators, etc. *And* you won't have the "learning curve do-overs"!
Talk to the body shops to find out what they would charge. Or, maybe there is a skilled painter in your area who does spray jobs on the side, since you don't need all the services of a body shop.
Heck, if you are getting into welding, too, you might even build a "rotisserie" to make the painter's job easier, if he doesn't already have one. That sort of thing makes great welding practice, must be strong but doesn't need to be particularly pretty!
I'd love to re-learn painting some day, but meanwhile I think I'll just leave it in the hands of a pro.
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
