OK, almost ready to drop the body back on my TR6. Does anyone know what order the shims+hardware go? I've a box o' parts from TRF, but the drawings(sadly) do not indicate the order of the parts--ie Frame,rubber,shim, body, washer, bolt? Or frame, shim, rubber, body, washer bolt? There's probably a few more permutations, but those two are the most likely...Maybe frame, rubber, shim, rubber, body, washer, bolt? I think that the main tub (the big four points, get frame, rubber, shim, rubber, body, washer, bolt (if a shim is needed, else, just frame, rubber, body, washer, bolt.)
I'd fall back on what it was when I took it apart, but there was no consistant order of the mountings.
Thanks--
BobH
Thanks--
BobH
