TR2/3/3A Body Mounting Strip Adhesive
Joel M
What's a good adhesive to use to attach the 6 body mounting strips (from TRF) to the frame? I just tried to glue them using 3M Super Weatherstrip Adhesive, and let's just say it was an unmitigated disaster. The strips curled up on all the long edges and would not stay down. The manual says to use Bostick C (unavailable in the US?), but I thought the 3M adhesive would be a good alternative. It was not. Any ideas?
Joel
DavidApp
I used a small amount of the contact cement you can get at Lows or Home Depot. Comes in a can. I used Weather strip adhesive on the boot seal and it did not work too well. Went back to contact cement.
David
martx-5
Contact cement...Wellwood in the jar because that's what I had laying around.
J
Joel M
Thanks for the advice, all. I picked up some Weldwood contact cement from Lowe's this afternoon, and it worked great!
malbaby
If you car has unknown history....Be aware that you may need varying thicknesses of mount strips to compensate for any body or chassis twist that may have occurred in the past.
Whilst on the ground with the chassis weighted...Check the door gaps especially before bolting the body down securely.
J
Joel M
I'm actually getting ready to post a request for advice on the steps I need to follow for the required body work (inner and outer sill replacement). Regarding the strips, I just glued down what I believe was there previously and also shown in the manual. I may have jumped the gun, but the history of the car is fairly well know. My father purchased it brand new in 1960.
J
Joel M
Thanks for the link David, I will reach out to them for availability and cost.
The floor pans do have some rust, but they seem sturdy. My plan was to blast them after they are removed for inner sill replacement, and then make a determination if they can be re-used. Although I'm not entirely sure if I can remove them without damaging beyond they point of re-use.
DavidApp
They can be a bit slow with their e mail responses. Price I got for the seat pan was good.
If the floor pans are not too bad you may be able to cut a piece from a new pan and save having to remove the complete thing.
I gather the best practice is to remove one floor pan or inner sill at a time to retain the body integrity.
Brace the door gaps to prevent movement. Can make it a PITB working around the braces but beats having to try to get the gaps correct again.
Rodger Williams book "How to restore a TR2, 3, 3A, 4 and 4A" goes into the body bracing.
David
J
Joel M
Thanks David! I'm about to submit a post with pictures and a draft plan that lay out what I'm thinking. I hope you will read and give me your feedback. This is the first body restoration I have done, so I would appreciate your advice.
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
T TR2/3/3A Question on TR3A front body mounting Triumph 6
S TR2/3/3A Body Mounting Bolts. Triumph 14
T TR4/4A Body Mounting Strips Triumph 0
P TR4/4A Body mounting plate location? Triumph 2
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
A Body mounting to frame Triumph 7
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
M Mounting the body on the frame Triumph 11
G body mounting Racing 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
