TRclassic3
Thoroughly stumped here. I have a very visual body lean to passenger side. Measuring at the wheel wells there is a 1 and 3/8 inch difference in the front and 5/8 in the rear. Performed a number of measurements against frame and suspension and did not encounter those kind of differences. Also used a level on the frame (looked good) and with bonnet up, across the engine bay. The last one basically reinforced the measurement at the wheel wells. I can find no body to frame issues. That is the pads appear in place and reasonably equal and the floors and outriggers are solid. Need suggestions on what to check next. Does the fact that the problem is worse in the front than the rear point to front suspension (coil spring maybe) rather than rear leaf? Any way to verify one or the other? Visual inspection has not turned anything up. Really would like to avoid just throwing parts at it.
Thanks in advance
Thanks in advance
Hi Guest!
