bn6/7 hardtop
maxwedge5281
there was a nice two seater factory hardtop on ebay that bidding ended on yesterday about noon. it sold for 3800 which seems to be a good price. however it was the wrong color for me, did not have latching hardware, and i would have had to drive to pennsylvania to pick it up,,,seller would not ship. also for my needs the three piece rear glass would need to be replaced...so...all this added another 1000-1500 dollars so i based my top bid on that premise.
i am still looking but perhaps a new one might not be so much more expensive. does anyone have experience with pete farmer tops? cape international tops? nical engineering tops? trying to decide which one appears to be closest to the factory hardtop. does the two seater top and the four seater top have the same overall dimensions? any pictures or advice appreciated!
RA_Healey
I have been looking at one for my BJ-8 and have been looking at the sources you have listed. We have a club member that was looking for a 2-seater top for from these same sources.
A H Spares sells them also but not one for a 2-seater and do not know who makes them.
From my understanding, Pete Farmers will be a very good fitting top. I think they all come partially assembled and you have to do the rest but do not know what that entails. However, they are not an exact factory original type but they still look nice. He does not have all the aluminum pieces and the vent is not an original type.
I saw a BJ-8 top from Cape International this fall on a car. Not the best quality. I think they come already painted. His was black. The fiberglass was chunky looking, waves in it. The aluminum trim was not very good looking. I don't know who makes theirs.
From everything I can gather, Nical Engineering may be the nearest to factory looking but by far the most expensive for a 2 seater.
See these two posts and maybe they can give you input. I would be interested to what you find.
https://www.britishcarforum.com/bcf/showthread.php?66389-BJ7-or-BJ8-Nical-hardtop-ques
https://www.britishcarforum.com/bcf/showthread.php?10527-NICAL-100-Hardtop
HealeyPassion
My understanding of the hardtop situation.... Cape Int'l gets theirs from someone.... think it's Pete Farmer but could be Nical. I'm pretty sure that Nical and Farmer are the only ones making hardtops so imagine all hardtops being sold are from one of those two.
Nical's is the most original... Nick Freeman, owner of Nical Engineering took is mold off an original that needed complete restoration (fiberglass was badly deteriorated)...I was also told that he got the patterns for the aluminum from the factory when they closed down production (the late Jonathan Everard of JME Healey's in the UK said he used Nical's). So the good news is that's it's extremely accurate... the bad news is that it's extremely accurate. Meaning, that the problems with the original also exist on the reproductions. Supposedly, Pete Farmer has maintained the original look but fixed the issues with the original hardtops... I've never seen a Pete Farmer hardtop so I can't verify that... nor can I comment on the Farmer quality since I haven't seen one.
I have a Nical hardtop on mine BJ7.... it's a good fit, albeit with the issues of the original. I've seen/inspected an original and it seems to be exactly like my Nical hardtop (or, I guess it's really the other way around)..
FWIW.
Cheers,
Steve
Patrick67BJ8
FWIW.
Cheers,
Steve
I can't wait to get started on installing my Nical Hardtop on my BJ8. Please post your blog website again. Thanks!
Michael Oritt
Maxwedge--
I must have been very lucky when I bought a 2-seater hardtop for my then-wife's BN7 about 7-8 years ago: There was a fellow with an AACA Gold level BN6 who sold his car to a person who did not want the hardtop. I bought it for $2000.00 and after new windlacing and a paint job I had a very good top.
Forget about trying to use or change a 4-seater top. They are absolutely different animals and many folks have learned the hard way that if you have a two-seater you need a two-seater top. You just cannot use the more common four seater tops and adapt them. BTW the back window is one piece--not three. The two bars fit inside the back window and are there, I guess, to stabilize the shape of the top.
I bought a top for my 100 from Nical when he came over to Conclave in North Carolina to sell his BJ tops and he also brought along the 100 model. I can only hope that Nick has become more responsive to customers' needs than he was when I--and the late Healey maven Dave Russell--were fitting his tops and side curtains to our cars. The curtains he initially sold me and the back window he furnished were way far from correct and though he eventually did come across with acceptable replacements it took a lot of cajoling and patience to get him to do so.
I don't know whether he and Farmer used different patterns--they each seemed to claim to have the best product that the other ripped off but in any case try to see an example before you purchase anything as these parts are expensive and obviously not returnable.
maxwedge5281
maxwedge5281
michael, is the two seater top the same overall dimension as the four seater, with the difference being along the rear of the top where it meets the surface of the body? yes, i knew the rear window was one piece, but the ebay car had as he called it a rally works rear which was made in three seperate pieces. the two outside pieces actually had what appeared to be maybe 6 one inch holes drilled into the perplex??? or what ever material! i had never seen that before.
hmj6854
I have a Nical hardtop on my BJ8. Purchased it in 1999. Got around to installing it a few years into the restoration. Difficult to assemble and get on, but pleased with the results. I haven't dared take it off since....
RA_Healey
hmj6854:
Got any photos of it showing the trim?
Did yours come painted?
How many pieces did it come in, crated?
Fiberglass smooth?
Thanks if you can do this, understand if you can not. I have not figured out how to post photos. Probably is simple.
Jeff
Mert
Here is a photo of my BN7 that I had just purchased in San Francisco in 1988. The top was unique. Unfortunately, it got blown off the car and was severely damaged as I was towing it. I was too dumb to realize it could have been repaired. I do not know the name of the manufacturer. I know it is not Nical, Dyna-plastics, Cape Intl, Smoothline, AH spares, Kellison, or Ashley Laminates. DOES ANYONE RECOGNIZE THIS TOP? I am just curious as to where it was manufactured.
maxwedge5281
maxwedge5281
yes that is a bit too unique for mei i am asking about a two seater factory hardtop or a very close reproduction of one. i imagine that top would be quite valuable today. thanks for the pictures!
maxwedge5281
maxwedge5281
i just received a quote from pete farmer for a complete hardtop...much like the factory hardtop....4200 pounds and the rear window has to be fitted and the top painted...3800 dollars for the ebay top was a steal. wish i had received the quote sooner. i would have bid much more than 3750!!! and the top has to be shipped which would put the cost of a new factory reproduction top at or above 7000 dollars!!! a ridiculous price in my estimation...
HealeyRick
I think that was the ACME top (no relation to Wile E. Coyote)
Michael Oritt
"michael, is the two seater top the same overall dimension as the four seater, with the difference being along the rear of the top where it meets the surface of the body?"
Maxswedge--
I do not have any tops to measure but I assume that the two and four-seater tops would be of similar dimension except where the top contacts the rear deck or squab. The two-seater top is definitely longer and the window is bigger. Theoretically you could make a two-seater top into one for a four-seater but not vica versa.
nevets
To my knowledge the Healey 2 seater hard top is different than the 4 seater and they are not interchangeable nor modifiable to suite the other.
blueskies
Has anyone come across an aluminum (presumably after-market) hard top for these cars? One of my project cars, a BN4, came with one of these hardtops. The rear window appears to match the original in size and shape, and it has the two support bars inside by the window. I'm wondering who made these tops and anything else about them.
Jim_Newman BN6 hardtop for sale Austin Healey 1
Jim_Newman Hardtop BN7 vs BN4 [BN6 vs BT7] Austin Healey 7
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
nevets BN6 horn button Austin Healey 17
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
