ahealey1004
Hi folks...I've been working on a bn4 with stock drums, and after replacing the rubber flexible lines (2 front and the 1 at rear axle), all wheel cylinders with new (4 fronts, 2 rears), newly relined shoes, turned drums, new Moss master cylinder(bench bled it before installing)....I still can't get a firm pedal. At first it felt like I had a bad master cylinder, so I tried another one, still have the same issue. I've bled the brakes multiple times. I've checked for leaks and have none.
If I push it slowly it goes all the way to the floor. It was suggested to me by some Healey guys to make sure the eccentric adjusters were correctly positioned, and they are. My next step is to replace the brake switch and see if perhaps that helps.
Any suggestions are appreciated!
thanks,
Austin
thanks,
Austin
