Gundog61
The first problem is, I believe, the wrong gear oil was put in the steering box. The lower seal is leaking and the oil is just running out of it. I have since put in the correct fluid and maybe it will be less of a problem.
My real question is Has anyone been able to change this seal without removing the box or doing a top end rebuild? After removing the Pitman arm, can the old seal be removed and replaced?
