Bn1 four speed?
Daniel6364
Hi all, happy thanksgiving! In my BN1 that I'm currently restoring I've discovered that it has four forward speeds. Although I've yet to drive it on the road I'd like to know the possible reasoning for this and help identifying the current transmission. This is a project my father brought home in pieces about 26 years ago and about 2 years before I was born. He owns quite a few british cars-bj8, sprite, tr3, tr250, an mga coupe and one or two that I'm forgetting. Any help would be appreciated. Also he has never driven the Bn1
The correct "3-speed" xmsn for a BN1 was actually a 4-speed with 1st gear blanked off; that accounts for the goofy shift pattern.
People have tried "unblocking" 1st gear, by simply removing a plate where the selector rod is (myself included) only to discover that it really is useless! You'll hit the poor engines redline after about an eight foot (8') sprint. It just is not worth the effort, unless maybe you also swapped in something like a 2.73:1 final drive ratio.
On the otherhand, your car may be fitted with a BN2 trans. The BN2 "side-shifter trans for the Big Four cylinder engine looks just like this one for my BN6 6-cylinder engine, but with a different bellhousing, to accomodate the mechanical (versus hydraulic) clutch actuation.
Michael Oritt
Randy's two scenarios are both correct and it would be easy to determine whether the transmission is a 3-speed with the starting gear unblocked or a BN2 four speed by simply determining what is the shift pattern. The original BN1 transmissions had the lower gears on the right side, with in this casse 1st upper right, 2nd lower right, 3rd upper left and 4th lower left, whereas BN2 transmissions would have a conventional H pattern with 1st upper left, etc. etc.
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Healey Nut BN1 at Auction on eBay Austin Healey 4
