BN1 / BN2 Top Installation
TodE
I am replacing the top on my 1955 BN-1. It seems pretty straight forward, all but the stappleing the top to the wood header rail. I read Moss note in there catalog stating that the top installation should be done by a professional shop with Austin Healey experience? Am I missing something?
I did a search on BN1 top installation, but did not come up with anything. I looked on Healey 6 website, all they had were the differences in the BN1 bows and how they erect.
Did Rich Chrysler post anything anywhere?
Thank you
T
TodE
OK 40 views with no comments? How about pictures of the installation progression.
Thanks once again!
I've done all the other Healey tops, including a Spridget, but never one for a 100, so I can't offer much specific help there, but generally speaking...
The tops are not hard to do, just a close attention to details. Look REAL GOOD, including numerous pictures of what you're taking apart, even if it only resembles a top (torn to shreds) because that's how you need to put it back together!
NUMBER ONE: avoid the instinct to stretch the top too tightly, as it will definitely shrink in the sun; you want to pull all the wrinkles out, and not be *baggy* but not so tight that when you bounce a quarter on it, it goes into orbit!
I highly recommend that you buy (or rent) a pneumatic staple gun with the long-reach neck on it. You'll appreciate having it, and so will the thumbs you don't hit with a tack-hammer! Visit an upholstery store's website to see what's available. You need the long-nose to accurately get inside the "hideum" strip. I have one that looks similar to this one:
Not much else I can say about it; look at a few online tutorials, even for a variety of different cars, and take what you've learned and apply it to your 100. Here's the link to a BJ8 top I did a few years ago (and it had been a very long time since I had done anything as simple as an MGB top, and that was my first on a BJ8): https://spcarsplus.com/gallery3/index.php/reMKIII/top_work
Good luck! Take lots of pictures, so the next guy will benefit from what you've learned!
G BN1/BN2 Sidescreens Austin Healey 0
J 100 bn1/bn2 id Austin Healey 26
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
F BN1 vs Bn2 gear box Austin Healey 23
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
roscoe BN1/BN2 Alternator Conversion Austin Healey 7
A Sidecurtains for BN1 OR BN2 Austin Healey 1
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
F BN1/BN2 Clutch linkage Austin Healey 4
Vineyarder BN1 BN2 Transmission Question, Returning member Austin Healey 0
F BN1 or BN2 for sale in Europe? Austin Healey 3
ShawnC_at_Moss BN1, BN2 Carb Bodies with shafts Austin Healey 0
bighealeysource Anyone ever mount a side exhaust on a BN1 or BN2 Austin Healey 16
T BN1 / BN2 Horns Austin Healey 2
Frankenhealey BN1 or BN2 Hood? Austin Healey 3
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
T BN1 3 Speed to BN2 4 Speed Austin Healey 15
timbn2 are these from a BN1/BN2 by chance...? Austin Healey 20
AH100M BN1 and BN2 two-tone Austin Healey 2
roscoe BN1/BN2 windshield Austin Healey 1
1 100-4 BN1/BN2 Drivetrain wanted Austin Healey 0
P BN1 / BN2 with a serious identity problem Austin Healey 1
A bn1-bn2 recognition Austin Healey 9
jtb55 Conversion of front brakes from BN1 to Bn2 Austin Healey 9
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
