I have a 1955 Healey BN1, which has retrofitted BN2 front drum brakes. I have a problem with dragging front brakes, rears seem fine. I can pump the brake pedal as much as I like with the car stationary, except after a run. The brake pedal then has less free movement, the brake lights remain on, and the front brakes become very hot, a sign of residual pressure in the system. Initially I thought this might be due to a blocked return port in the (new) master cylinder, but this seems unlikely as it would affect all 4 wheels. I’m zeroing in on faulty front brake pipes, which were recently replaced, but which might be restricting return fluid when the brakes are hot or have been used for hard braking. Light braking causes no adverse symptoms, but hard braking seems to cause residual pressure in the system. Does anyone have any ideas about what might be going on?
